I have updated brave, the password autocompletion works but if I go to the password section I don’t see any passwords, I can’t see the value of the passwords either. If I go to the Login Data file the sqlite has all my passwords inside with their urls and usernam, how can I solve this problem or decrypt the passwords to export them to csv, I have the base 64 brave value from keyrings.
@hectormartin42 I do believe this is related to Aggregate Topic: Lost Passwords in July 2024 update so you can check that out and try some of the options.
Only thing throwing me off is mention you and a couple others have made that the password autocomplete still works. I’m going to tag in @Mattches just to confirm if that might be a slightly different issue or if indeed thinks they are related.
@hectormartin42 Yeah likely the same issue that was linked by @Saoiray above.
