Problem with authentication - brave
Description of the issue: Hello, I have an authentication problem on brave browser on Desktop PC. System refuses to synchronise on brave. What could be done to fix this issue ?
Brave Version( check About Brave): Release Notes V1.31.87 (Oct 19, 2021)
What errors are you seeing?
If you’re on Windows 7, please see this before continuing as it could be the same underlying problem: For users encountering NET::ERR_CERT_DATE_INVALID Error
Hello, actually windows 10. Another type of error - Payouts are on time. However I cannot link uphold rewards to my PC Brave browser. There is an error and during process of verification. Verification is being processed but process itself stops, refreshes several times and query is cancelled
Is there any update ?
I can’t really comment on the Rewards issue, hopefully others can chime in.
Regarding Sync, I don’t think I’ve seen the error or behavior described yet. Can you give a description of what’s happening?
Also, please make sure you’re on 1.31.91 at this point as well.
