Problem using Remote Desktop
Hello.
I installed Brave a couple of days ago.
The problem i’ve been up with it’s Remote desktop related.
I use it in a laptop and the issue goes like this: -if my laptop screen it’s open, all work fine - if my screen it’s closed i can use everything else but the Brave browser
Thanks
Just go to settings and make the screen to stay active all the time, I believe this can solve the problem. I was facing the same problem for some time, but it got fixed in one of the updates, and now is working properly. This can be the reason why the program is not working when your screen turns off. I buy rdp for a few years already, and they fix really fast the bugs like the one you described, if they appear of course. You should try it, I am almost sure it’s because your system is outdated
I have just encountered the same sort of thing. Except that brave disconnects the PC which I launched it on… So I can’t access that PC now… jeeees!
Each time I reconnect I don’t have enough time to close brave before it will disconnect the RDP connection.
THIS HAS ONLT HAPPENED SINCE THE LAST UPDATE,
Version 1.22.70 Chromium: 89.0.4389.105 (Official Build) (64-bit)
