Problem signing into Informed Delivery® by USPS®
I am trying to log into Informed Delivery® by USPS® https://informeddelivery.usps.com/box/pages/intro/start.action
It fails to log in, it just comes back to the login page. I have tried clearing browsing data and cookies and that did not help. It works OK on Chrome.
How do I fix this?
Thanks
@RonTon
I am using Shields v1. Screenshot of the site-specific Shields (Lion icon) panel, shows JavaScripts that you might consider, to select and Allow:
Screen Shot 2022-06-30 at 4.28.52 PM
You probably need to Allow:
  • www.usps.com
  • ajax.googleapis.com
I am uncertain about:
  • maxcdn.bootstrapcdn.com
If you want to use Shields v1:
In a Brave Browser - New Window, go to: brave://flags
Search for: Enable Brave Shields
  • DISABLE: Enable Brave Shields v2
  • ENABLE: Enable Brave Shields v1
Also, when you visit the website, right-click on the padlock icon located off the left end of the URL address field.
Scroll down in the resulting menu and Allow: JavaScript
Before trying @289wk’s suggestion, you might try simply turning Shields off for the site entirely and isolate whether or not Shields is having any effect on the behavior at all.
I regularly use USPS Informed Delivery, and have no trouble signing in with default shields settings (block trackers & ads, block fingerprinting and block cross-site cookies.)
