Description of the issue: I have issues when visiting website. I can’t select an “alternative” with the right menu or change language in comments.
Exact URL of the website in question: https://www.wow-petguide.com/?Strategy=969
Did the issue present with default Shields settings? (yes/no) Yes
Does the site function as expected when Shields are turned off? No
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no): Yes, I’ve found in console that the problem is ERR_CONNECTION_RESET with jquery. I’ve disabled Shields on the jquery website to solve the problem.
Does the site work as expected when using Chrome? Not on Edge with adblocker but it works on Firefox
Brave version (check About Brave
): 1.20.110
