Hello my brave is yousing between 90 and 100% of my hard disk how to fix this problem
Thanks
Version 1.47.186 Chromium
(https://brave.com/latest/)
Thanks
Hello @dochev, thanks for sharing your concern with us. Have you tried clearing your cookies and cache recently? Do you use many extensions or bookmarks? How many tabs do you have open? can you try disabling this Settings --> Additional Settings --> System --> Hardware Acceleration
Let us know if that helps. Regards.
I don’t collect data or cookies but the problem is from Hardware Acceleration i turn it off and is okay. No disk usage.
Thanks
Nope it stops for 10 min and start using the HARD disk again at 90%
Is it possible to mine crypto in the background without my knowledge
It stop from it self don’t know what was the reason. For know is okay !
