I’m new, I want to know if the rewards earned are withdrawable? and if yes, what’s the minimum withdrawal amount?
Yes, you can connect your Rewards wallet to your Uphold wallet – available for desktop and Android.
You may need to accumulate 25BAT first before you able to connect it. https://support.brave.com/hc/en-us/articles/360034841711-What-is-a-verified-wallet-
Hi if we are content creators we can also use the Gemini wallet to transfer our BAT, isn’t that correct ?
Awesome, thank you for the feedback, I really appreciate.
