Passwords in settings split second popup issue macos 14
Go into the Settings → Passwords
Click on any saved password and the osx (fingerprint) password popup opens for a split second and then disappears.
Unable to access saved passwords (I need to copy one into safari) since you need to enter your admin password to access
I just noticed this - i upgraded to macos 14 sonoma a couple weeks ago.
@jason-engage,
Not seeing this on my end — touch ID prompt stays up as expected. Do you have any extensions installed at this time? If so, you might try disabling them and testing again to see if one of the extensions installed was causing a conflict with the prompt.
