@Mk101,
The tab strip there should disappear as you scroll down on the site. So from where you are there, if you just scroll down a tiny bit the strip should disappear and you should be good to go.
Yeah I agree that’s what should happen but I’ve had instances where it didn’t. One example is a couple weeks ago I was on Facebook marketplace (desktop site as you can’t list to sell on mobile site) and was trying to list something. It wouldn’t go away and so I couldn’t click the next button right at the bottom on the mobile (pixel 7). Now, however, it did go away.
It sounds like the issue is intermittent and likely dependent on the fact that you’re using the site (Facebook, in this case) in Desktop view rather than mobile view.
Do you have a way to reproduce this issue consistently?
Actually I just worked it out. If you click on more details on the left it expands the window. On my current layout it expands it to a size whereby I can’t see either the address bar or the tab selector no matter what scrolling I do. If I go to another app and come back however I can see them, and no matter what scrolling I do the tab selector doesn’t disappear and blocks the next buttons.
