Page search box uses white text on white background when using the light color theme
When searching using Ctrl/F, it’s not possible to see the entered text when using the light theme in Brave since the input field uses white text on white background.
Brave version:
Version 0.72.106 Chromium: 78.0.3904.50 (Official Build) dev (64-bit)
OS: Windows 7 Professional SP1
I see the same on MacOS (came here to report it), started a few days ago. My current Brave Dev: Version 0.72.110 Chromium: 78.0.3904.70 (Official Build) dev (64-bit)
I see the same problem in the authentication dialog for sites that use basic HTTP auth. For example (there is text in the text fields):
In dark mode, the text shows up correctly:
Same problem here on Windows7 enterprise SP1
The problem appears for search dialog box and the authentication dialog box.
Today’s update to version .72.116 appears to have correcting the issue with the light theme. Text appears normally now it the few boxes that have opened for me.
Same here, the .116 update fixed it! :slight_smile:
