But I do have some verbose logs about this
@steeven
I put whatever I found was relevant
[ REQUEST ]
URL: https://grant.rewards.brave.com/v1/captchas
Method: POST
Content: {“paymentId”:“xyz{should I share}”}
Content Type: application/json; charset=utf-8
[07 Aug 2022, 1:14:55.0 am:VERBOSE6:logging_util.cc(137)]
[ RESPONSE - OnRequest ]
Url: https://grant.rewards.brave.com/v1/captchas
Result: Success
HTTP Code: 200
Body: {“hint”:“square”,“captchaId”:“xyz{should I share}”}
[07 Aug 2022, 1:14:55.0 am:VERBOSE5:ledger_impl.cc(114)]
[ REQUEST ]
URL: https://grant.rewards.brave.com/v1/captchas/xyz{should I share}.png
Method: GET
[07 Aug 2022, 1:15:00.9 am:VERBOSE5:ledger_impl.cc(114)]
[ REQUEST ]
Method: PUT
Content: {“solution”:{“x”:237,“y”:145}}
[07 Aug 2022, 1:15:01.2 am:VERBOSE6:logging_util.cc(137)]
Url: https://grant.rewards.brave.com/v1/captchas/xyz{should I share}
Result: Failure
HTTP Code: 401
Body: {“message”:“: Error solving captcha”,“code”:401}
[07 Aug 2022, 1:15:01.2 am:ERROR:put_captcha.cc(55)] Invalid solution
[07 Aug 2022, 1:15:01.2 am:ERROR:attestation_desktop.cc(154)] Failed to confirm attestation
[07 Aug 2022, 1:15:01.2 am:ERROR:promotion.cc(366)] Attestation failed CAPTCHA_FAILED
[07 Aug 2022, 1:15:01.2 am:INFO:confirmations.cc(108)] Retry sending failed confirmations
[07 Aug 2022, 1:15:01.2 am:INFO:confirmations.cc(237)] Removed view confirmation for inline_content_ad with id xyz{should I share}, transaction id xyz{should I share} and creative instance id xyz{should I share} from the confirmations queue
[07 Aug 2022, 1:15:01.2 am:INFO:redeem_unblinded_token.cc(50)] Redeem unblinded token
[07 Aug 2022, 1:15:01.2 am:INFO:redeem_unblinded_token.cc(121)] FetchPaymentToken
[07 Aug 2022, 1:15:01.2 am:VERBOSE2:redeem_unblinded_token.cc(122)] GET /v2/confirmation/{confirmation_id}/paymentToken
[07 Aug 2022, 1:15:01.2 am:VERBOSE6:redeem_unblinded_token.cc(126)] URL Request:
URL: https://anonymous.ads.brave.com/v2/confirmation/xyz{should I share}/paymentToken
Method: kGet
[07 Aug 2022, 1:15:01.2 am:VERBOSE5:ledger_impl.cc(114)]
[ REQUEST ]
Method: POST
[07 Aug 2022, 1:15:02.0 am:VERBOSE6:logging_util.cc(137)]
Result: Success
HTTP Code: 200
Body: {“hint”:“circle”,“captchaId”:“xyz{should I share}”}
[07 Aug 2022, 1:15:02.0 am:VERBOSE5:ledger_impl.cc(114)]
[ REQUEST ]
Method: GET
[07 Aug 2022, 1:15:02.4 am:INFO:redeem_unblinded_token.cc(137)] OnFetchPaymentToken
[07 Aug 2022, 1:15:02.4 am:VERBOSE6:redeem_unblinded_token.cc(139)] URL Response:
Response Status Code: 200
[ REQUEST ]
Method: PUT
Content: {“solution”:{“x”:221,“y”:133}}
[07 Aug 2022, 1:15:10.4 am:VERBOSE6:logging_util.cc(137)]
Result: Success
HTTP Code: 200
Body:
[07 Aug 2022, 1:15:10.4 am:INFO:database_creds_batch.cc(131)] Record size is not correct: 0
[07 Aug 2022, 1:15:10.4 am:VERBOSE5:ledger_impl.cc(114)]
[ REQUEST ]
URL: https://grant.rewards.brave.com/v1/promotions/xyz{should I share}
Method: POST
Content: {“blindedCreds”:[“xyz{should I share}”],“paymentId”:“xyz{should I share}”}
Header digest: SHA-256=xyz{should I share
Header signature: keyId=“xyz{should I share}”,algorithm=“ed25519”,headers=“digest (request-target)”,signature=“xyz{should I share}==”
Header accept: application/json
[07 Aug 2022, 1:15:10.7 am:VERBOSE6:logging_util.cc(137)]
Url: https://grant.rewards.brave.com/v1/promotions/xyz{should I share}
Result: Success
HTTP Code: 200
Body: {“claimId”:“xyz{should I share}”}
[07 Aug 2022, 1:15:10.8 am:VERBOSE5:ledger_impl.cc(114)]
[ REQUEST ]
URL: https://grant.rewards.brave.com/v1/promotions/xyz{should I share}/claims/xyz{should I share}
Method: GET
[07 Aug 2022, 1:15:11.1 am:VERBOSE6:logging_util.cc(137)]
Url: https://grant.rewards.brave.com/v1/promotions/xyz{should I share}/claims/xyz{should I share}
Result: Success
HTTP Code: 200
Body: {“signedCreds”:[“xyz{should I share}”],“batchProof”:“xyz{should I share}”,“publicKey”:“xyz{should I share}”}
[07 Aug 2022, 1:15:11.1 am:ERROR:credentials_promotion.cc(406)] UnBlindTokens: Unblinded creds size does not match signed creds sent in!
[07 Aug 2022, 1:15:11.1 am:ERROR:promotion.cc(515)] Credentials process not succeeded LEDGER_ERROR
[07 Aug 2022, 1:15:11.1 am:INFO:promotion.cc(445)] Promotion completed with result LEDGER_ERROR
[07 Aug 2022, 1:15:11.5 am:INFO:confirmations.cc(108)] Retry sending failed confirmations
