Every time I boot up in Mac OS Ventura, Brave gives me notice in System Preferences that it has been added to the Items that will be opened at login. I have deleted this 4 times now and every time I boot up, I get the notice yet again that Brave has been added to the Auto Login How can this issue be reproduced?
Every time I reboot
1.45.113 Additional Information:
@bkarlan,
We’ve seen this issue before and it is typically due to an extension installed in the browser — can you tell me if you have any installed extensions (and if so, which ones)?
I was having the same problem here with my update to Ventura. I disabled all my extensions and it seems to have fixed the problem. I had a bunch of active extensions though, so I haven’t determined which one(s) were the cause. I’ll report back here if / when I can figure it out. Thanks!
