Not seeing Brave Rewards ads after operating system crashed
Hello,
Any idea why I am no longer seeing ads after my operating system was restored? All the Brave Rewards settings appear to be correct.
Thanks,
Jason
The ads notifications will need to be re-authorized in your OS settings; are you on Windows or Mac?
https://support.microsoft.com/en-us/help/4028678/windows-10-change-notification-settings
Make sure Brave notifications are enabled :slight_smile:
Hi there,
I’m using Windows 10. I see that all my notifications are turned on, however, I don’t see Brave in the list of senders. Would I have to re-install Brave?
Thanks,
Jason
@Jayko12 visit https://www.bennish.net/web-notifications.html and try to enable notification. Then, see if Brave is listed on your Notification settings.
Thanks
That worked! Thanks guys, it looks like I am back up and running. Have a great day.
