Need help with problem opening "Sketchup application" in Brave Browser
I used to be able to use the ‘Sketchup Application’ by Trimble on the Brave browser. But now I’m unable to, getting the notification: “Sorry. We encountered a problem with your web browser’s WebGL support.”
Under shields, allow all cookies and allow all Cross-site device recognition see if this helps
Awesome! it worked. Thanks a bunch!
Just a quick question, which option helped @Roido ? Allowing all cookies or Device recognition ?
