hi, so i resetted my windows 10 and then i copied the default folder from brave because i thought you can just swap it with the new one but no, it says that brave got corrupted by another programm so it resetted my settings now i cant restore my passwords and stuff can this issue be solved?
Rather than doing via the folder method, you do it via sync method brave://settings/braveSync/. Put your relevant info on the sync chain, then whenever you need it you can get your data directly from sync server.
Also, I would recommend using a password manger. It is more privacy-friendly, secure, and stores the data on the cloud in encrypted format. Bitwarden is the most recommended password manager.
