Need help regarding frequent and random website crashes
When I try to load various sites i will receive an error message that I am unsure of how to fix or avoid.
I have looked online for ways to solve and fix this issue but I have not been able to find any, I have seen posts covering solutions to very similar issues but none the same as mine. This issue also occurs on other chrome based browsers.
I have Norton 360 VPN installed, I have had it for over a year though people commonly ask if you are using a vpn with similar issues.
My error message reads:
“Aw snap
Something went wrong while displaying this web page
Error code: STATUS_IN_PAGE_ERROR
Can you provide links to any?
Question is, have you tried anything? For example, toggling Shields? Disabling/removing extensions? Testing in a new browser profile?
And have you tried disabling VPN? If so, did it make a difference?
Other critical information you left out:
  • Which version of Brave are you using?
  • Which version of Windows?
