Very fast left mouse button then right mouse button clicks are changing the page zoom making it bigger and the window zoom widget appears on the screen then disappears almost immediately. Too quickly to use to reset the zoom to where it was before.
VERY quickly press left click then right click.
I’d like to disable the mouse from doing this. It’s annoying. And Brave is the only browser that does it. I’ve attempted to reproduce on Firefox, Chrome and Opera. ALL of those browsers see the right click as a right click and open the right click dialog box.
It happens all the time.
page in the main menu):
Version 1.35.100 Chromium: 98.0.4758.87 (Official Build) (64-bit)
Windows 10 Home 10.0.19043 Build 19043
When I say very quick left/right clicks, I mean very quick. Holding the left button down and then clicking right does not duplicate. It’s basically, “clickclick”. I’m using my index finger on left click, middle finger is over the scroller and ring finger is over the right button. So it’s index/ring, almost simultaneously. It’s the kind of thing that happens when you just happen to have your hand over the mouse and your fingers put enough pressure on the mouse buttons in the way I’ve described. REALLY ANNOYING.
