More granular controls for youtube element removal
I really like the feature of being able to disable some features of the YouTube site within the shield settings. But I was wondering if it is possible to take the 2 current sliders and break them out into more granular options? It would be cool if you were able to remove the comments, but not the video info or vice versa. Same with recommend content. If you could remove the end cards and up next, but not remove the navigation bar at the bottom on the home page could be useful. I don’t have either slider turned on currently as both remove more than desired for my use, and I think others may be the same. I have no idea if this is feasible and am just curious. Either way, thank you guys for the great work you do!
