Missing speed dial icon ANDROID
I have a missing icon in my speed dial on the second line last one at the end,tried everything to fix but still will not appear. Hope you can help…Cheers
I have also groupme noticed that i conclude that its nothing but a glitch or bug thats present. I think that should be fixed legto soon till then no answers.
Regards,
Shane.
Thanks dor reporting @freekshow150 @ShaneP.
Can you both share your Brave version and screenshot about the issue? I’m not really sure about that.
Thanks
:slightly_smiling_face:
