escknx
April 2, 2025, 5:46am
1
Recently, about 1-2 weeks ago, middle click no longer opens new tab from history
Only ctrl+left click works
Links and bookmarks middle click works fine, just history affected
It worked fine before.
Other Chromium-based browsers work fine
Brave Version 1.76.82 Chromium: 134.0.6998.178 (Official Build) (64-bit)
Win 10
289wk
April 2, 2025, 6:24am
2
@escknx
Your issue (Middle click does not work for History), might be a lingering Chromium problem:
Bookmarked links folder inside another folder is not opening with middle mouse
That also affects:
Middle Mouse button wont launch multiple URLs at once, but it used to
Middle clicking the mouse to open bookmarks folder stopped working
How and when a fix might be developed:
Generally, a Brave team member - such as @Mattches of Brave Support - passes the info “upstream”, and somebody among the higher-ups, who deals (word usage?) with Chromium, then passes the word on to Chromium.
Takes time for Chromium to fix, and that may not happen fast (but you may be surprised).
escknx
April 3, 2025, 2:50am
3
Weird cause vanilla Chromium works just fine. Although I may have an older version. Cause ti definitely happened after another Brave update
@escknx ,
Can you please check and see if the latest build of the browser resolves the issue? It was assumed to be an upstream Chromium issue:
We do have another report of this on Github:
opened 03:33AM - 06 Mar 25 UTC
feature/bookmarks
regression
OS/Desktop
### Description
Prior to this version of Brave you could middle-mouse-button (s… croll wheel-) click on a folder in the bookmarks and it would open all links in that folder in new tabs
### Steps to reproduce
1. middle-mouse-button (scroll wheel-) click on a folder in the bookmarks
2.
3.
### Actual result
Nothing happens.
### Expected result
All links in that folder should open in new background tabs.
### Reproduces how often
Easily reproduced
### Brave version (brave://version info)
1.76.73 Chromium: 134.0.6998.45 (Official Build) (arm64)
### Channel information
- [x] release (stable)
- [ ] beta
- [ ] nightly
### Reproducibility
- [ ] with Brave Shields disabled
- [ ] with Brave Rewards disabled
- [ ] in the latest version of Chrome
### Miscellaneous information
_No response_
