Using apps where your microphone is needed through the brave browser is almost not usable because of the noise cancellation, noise gate or whatever is being used in the browsers core, but using Discord, Guilded, and other apps (turning their noise suppression stuff off) is just an exemple, people can’t hear you easily, especially for people that are musicians like me where detailed and unfiltered sound is a necessity, maybe give us (the end-user) the option to turn it off manually, or remove the junk completely, but this is a huge turn off for me personally.
