Metamask does not work on Brave
Hello, I have a problem with metamask, even when I update Brave, turn Metamask off or even reinstall the browser, the Metamask icon does not appear. This problem has only happened to me in Brave and it seems that there are several people with the same situation, but so far I have not seen a concrete solution.
I would appreciate any help, thanks.
Brave: 0.22.669
V8: 6.6.346.24
rev: 6cda2e84f749e66409e9e3bca63f5796422e7edf
Muon: 5.2.7
OS Release: 10.0.16299
Update Channel: Release
OS Architecture: x64
Node.js: 7.9.0
Brave Sync: v1.4.2
libchromiumcontent: 66.0.3359.117
I couldn’t replicate on macOS for the same Brave version.
Would another Windows user please enable Metamask to give this a poke?
Thanks!
-I’ll also try on my Windows machines at home later today as well (currently working elsewhere)
#3
I do not have all the extensions for 2 months. Including metamask which I really need.
#4
You have to go into the brave folder, delete the Metamask extention, and the restsrt brave.
#5
Thanks for the reply, but unfortunately it did not work. Honestly it was difficult to find the brave files, but when I did it and deleted all traces of metamask, when I opened the browser and activated the extension (or opened it while metamask is activated), the folder was recreated but nothing changed
closed #6
