Messages Android website problem
It seems that https://messages.android.com has a popup error when one visits the website with brave.
It says “Pairing ERROR: An error has occurred. Click OK to refresh the page to try again.”
Hi @astzor!
This is happening because your Brave shields are up and you have them blocking 3rd party cookies.
To fix this, simply open your shields panel (lion icon on the top right), click the “cookie control” drop down menu and select “Allow all cookies”. The website would load normally :slight_smile:
Your shields settings are specific to each website, so when you run into a situation where a website is not functioning or loading properly, consider adjusting the shields settings for it!
Hope this helps!
#3
Thank you for tell me this!
#4
You’re very welcome!
Thank you for supporting Brave :slight_smile:
