Briefly describe your issue:
I lost access to a couple installs of brave and had to reimage my personal PC. So unable to receive brave rewards now.
)? win 10 21h1 , [
Version 1.26.74 Chromium: 91.0.4472.124 (Official Build) (64-bit)
**Is your browser wallet currently verified? no
What date did you verify your wallet? no
Have you been able to successfully receive payments in the past? yes
Are you using a VPN? (yes/no) no
Are you in a supported region (see here for list of supported regions)? Canada
Have you manually turned off Auto-contribute on all of your devices linked to Uphold?? yes
