issue:
There is a massive difference between what the pending rewards say and what is actually received. It used to not do this but recently (past 3 months or so) it has been saying things like 25+ BAT expected reward and only paying out like .25 or something around there. This has been the case for the past 3 months or so and it used to not do this. Nothing has really changed on my end either, including connection types. It has been paying out monthly contribs, but now I’m running low (2.5) as what is coming in is not representative of what it says I should be getting OR what I really should be getting. (I am getting more than enough ads).
Windows 10 Education (lol, just treat it like Windows 10 pro)
Nope.
Yes!
Are you using a VPN? (yes/no)
Sometimes
Yes.
No uphold wallet linked.
