Linux --class flag does not work
the chromium --class command line flag is not actually changing the reported application class. (this could be an upstream bug in chromium).
This manifests is in dock applications like Cairo-Dock and Dock-to-Dash.
Where setting the WM_CLASS manually via the --class flag doesn’t work,
then all the brave windows (including those run from their own shortcuts) are grouped under one icon, instead of having the applications that are run from their own shortcuts grouped under their own icons.
  1. launch a brave application from command line with --class=“test-class”
  2. I an new command line run “xprop WM_CLASS” and select the window
  3. Note that the class doesn’t change.
The application class should have changed.
Version 1.23.73 Chromium: 90.0.4430.85 (Official Build) (64-bit)
Linux Mint 20.1 Cinnamon
Cinnamon 4.8.6
Cairo-dock 3.4.1-3
xorg 1:7.7+19ubuntu14
I’m facing this issue myself on ArcoLinux.
I’ve also tested --class flag on Chromium - it works as expected. On Brave WM_CLASS is not changed.
brave --version
Brave Browser 90.1.24.82
chromium --version
Chromium 90.0.4430.212 Arch Linux
pacman -Qs xorg-server
local/xorg-server 1.20.11-1 (xorg)
