Lastpass 2-factor auth problem
windows
bug
I am a Lastpass user. I user 2-factor authication when logging in. The window where I should write my 2fa code in is not responsive.
To reproduce:
  1. Click lastpass icon
  2. Enter email and password
  3. On next page send code to SMS
  4. (Recive SMS)
  5. It is not possible to type or paste my code.
I am on windows 8.1
Lastpass multifactor auth don't work
Same issue also applies on Mac High Sierra 10.13.2
This effectively makes the extension unusable - back to Chrome in the meantime sadly
#3
This lastpass bug has rendered Brave completely unusable for me. I can’t login to last pass. There is no way to enter the SMS code into the text field to authenticate. Without this, I can’t log into email, and many other important sites… I love the concept of Brave, but I’m married to LastPass at this point. Back to Chrome for now. Hopefully this gets fixed!
I’m using a mac, 2013 with MacOS High Sierra.
#4
I have 2FA with time based one time password app and it’s working OK.
#5
Same problem here. I have Lastpass two factor authentication setup with an SMS code sent to my phone. Fresh install of the lastest version of Brave on MacOS High Sierra 10.13.2. Enable lastpass plugin and attempt to login. After entering my credentials I am then directed to the multifactor authentication screen, but it is nonresponsive.
I’ve searched through the forum and noticed several others have reported the same problem with Lastpass 2FA over the past year and the cases are always closed without any updates or resolution.
Lastpass recommends their users setup multifactor authentication so this plugin (and the whole browser) is useless for the millions of Lastpass users who follow the security recommendations.
#6
Same issue.
Windows 10
Brave 0.19.131
rev da2f347
Muon 4.5.36
libchromiumcontent 63.0.3239.132
V8 6.3.292.49
Node.js 7.9.0
Update Channel Release
OS Platform Microsoft Windows
OS Release 10.0.16299
OS Architecture x64
#7
I wouldn’t call it useless if you can setup Lastpass 2FA with TOTP.
#8
I don’t have the problem with Lastpass but I do experience it when logging into Vanguard.
Screen converts to only text and and clicking on continue does notwork.
#9
Logged https://github.com/brave/browser-laptop/issues/12999
Thanks,
Lauren
#10
Same problem here (exactly as in OP). Hope it’s fixed soon because Brave seems really promising otherwise!
Brave: 0.20.30
V8: 6.4.388.40
rev: 8b78402e7b3b91d44d8146cbe4dc8013592c33fd
Muon: 4.7.9
OS Release: 10.0.14393
Update Channel: Release
OS Architecture: x64
Node.js: 7.9.0
Brave Sync: v1.4.2
libchromiumcontent: 64.0.3282.119
#11
Same problem here. I had just discovered Brave and the philosophy behind it had me convinced that this was the browser I wanted to use. However, now I can’t log in to websites as I use LastPass for everything and I can’t authenticate anymore. Back to Google. At least that works.
#12
Also having this 2FA issue using Lastpass ext. On Windows 10. Quite annoying. Love the Brave browser, but cannot operate without a working lastpass extension or a workaround for this.
#13
Brave: 0.22.22
V8: 6.5.254.41
rev: 63033109963be0a995b3d1ed9723870beeb191c4
Muon: 5.1.2
OS Release: 17.6.0
OS Platform: macOS
Node.js: 7.9.0
Brave Sync: v1.4.2
libchromiumcontent: 65.0.3325.18
LP does not authenticate well. Especially when LP gives an error.
#14
Also having the same 2FA issue. Otherwise am loving Brave.
Click lastpass icon (Also sometimes unsure if related clicking on the lastpass icon the overlay renders off screen - disabling and enabling the extension fixes this)
Enter email and password redirected to lastpass 2FA page
On 2FA page click “Send SMS passcodes”
(Receive SMS)
Mac OS High Sierra 10.13.4
Brave 0.22.727
V8 6.6.346.32
rev 2c94bba
Muon 6.0.12
OS Release 17.5.0
OS Architecture x64
OS Platform macOS
Node.js 7.9.0
Brave Sync v1.4.2
libchromiumcontent 66.0.3359.170
#15
+1 from @paragbaxi via Lastpass multifactor auth don't work.
#16
+1 for Brave on macOS High Sierra with lastpass SMS 2fac. After sending SMS codes, the lastpass tab becomes unresponsive to clicks or typing or pasting so no login is possible.
Brave: 0.23.19
V8: 6.7.288.46
rev: 178c3fbc045a0cbdbe098db08307503cce952081
Muon: 7.1.3
OS Release: 17.6.0
OS Platform: macOS
Node.js: 7.9.0
Tor: 0.3.3.7 (git-035a35178c92da94)
Brave Sync: v1.4.2
libchromiumcontent: 67.0.3396.87
