I am constantly getting keyring login when I first run the browser.
Also, after about 10 minutes of use I get a motion sensor error and my internet connection completely goes. I have to restart my computer for internet to come back on.
Is it Ubuntu with auto login enabled by any chance?
Found a few articles, maybe will help. Not clear to me at this point what the relationship is between the keyring and the browser (any browser) in this environment but it looks like it could happen with others as well, depending on the order and manner in which things were configured.
Thanks for the reply. I am not stating they are related. I am listing two problems I am encountering specific to ONLY the Brave browser. No other browser (Opera, Chromium, Firefox, Midori, etcâŚ) have this keyring issue and they donât disconnect me from the internet after 10 minutes of usage forcing me to restart my computer. As soon as I stopped using the Brave browser, I no longer encountered these two issues.
Yeah, I get all that. My statement about the âthe relationship is between the keyring and the browserâ isnât a criticism of your post, itâs just pointing out the fact that I donât understand, yet, why the other two browsers would NOT have this problem, but itâs likely that they were integrated together somehow at some point.
So to move forward, can you please answer the earlier questions, and also make sure you have gone thru those articles if they apply?
Another frustrating aspect to this is that I have to shut the computer down and restart each time to test if the Brave browser will launch the password window again. So I 1) edit something in the password area 2) reboot 3) relaunch the browser 4) see the window 5) edit something else in the password area and repeat from step 2.
I am not seeing much benefit in keeping the Brave browser. I would rather download and use a browser that doesnât launch this keyring login window out of the box. Or, make something in that window that has a checkbox âDonât show againâ.
The time it is taking me to find a solution could be used doing something else on the blue Chromium browser, Opera browser, and Firefox browser.
I have had to remove the Brave browser, it is hijacking my links when I click them and then I end up in an endless waiting cycle. Iâll revisit the Brave browser when it is more user friendly. I have college courses to get ready for and work to do. I canât spend all my time trying to find out why Chromium, Firefox, Opera, Midori, etc⌠work fine but Brave doesnât. If anyone else is having a problem, please visit this site: https://askubuntu.com/questions/1217043/how-do-i-remove-brave-completely
If you ever come back around to it and have issues again, you might want to start off by providing more information and answering helpersâ questions to move things along. For instance, you didnât even let me know whether or not you were running Ubuntu, nor whether you had Auto login enabled. From your last post I can deduce that it is indeed Ubuntu; but too little, too late it seems.
Folks, I donât think this is the OPâs issue but I wanted to log something here as it is related and other people may come across this thread if they hit the Keyring issue.
Funny enough, something similar just happened to me with Brave on a Fedora device. (I didnât lose Internet or anything like that; I just got prompted about an unlocked keyring.)
In my case it was because I started using biometrics (fingerprint) to unlock the device. Apparently, this does not unlock the GNOME Keyring. Maybe thereâs a setting for it, havenât looked yet.
But anyway, if I sign into the laptop with Password, it does unlock and I can access stored passwords without any further prompting. If I sign in using biometrics, the Keyring does NOT unlock, and when I open Brave, I get prompted.
I already uninstalled Chrome and Iâm not putting it back, but I can test some more later with Chromium and Firefox and report back. I have to assume the behavior will be the same because the Keyring behavior is observable before opening any apps at all, itâs doubtful that any other app would be able to magically unlock it and may even be concerning if so.
Yeah, so thatâs it. And Chromium does the same thing. Looks like this occurs if Seahorse is installed.
Firefox doesnât cause the prompt, but there IS a storage entry in the Keyring (Seahorse app) for it, so presumably it could require a keyring unlock at some point, otherwise it wouldnât have been able to store and access anything in it.
Seems thereâs a workaround some distros use for Chrom* browsers, adding some CLI options to use ââpassword-store=basicâ to avoid this. Might be something the Brave Linux package maintainers would want to look at? In one sense itâs a degradation, but it would also address a lot of user issues and questions.
If @tigerprowlusa is still paying attention to this thread, I think at least the first of your two problems is solvable using the above info. Your 2nd problem I have no idea, but one thing at a time.
But at the very least we end up with a better understanding of how this works on Linux platforms.
@Mattches, maybe something to get in front of the Linux package maintainers?
No, I donât actually have those additional problems the OP was dealing with â I only ran into the auth prompt.
If Seahorse is locked, I get the auth prompt when Brave starts up, but if I decline to unlock it a few times the prompting will stop and the browser loads.
At that point Brave seems to still work just fine, although my Sync settings are effectively disabled. They all appear to be turned off, and if I change them, they just get turned back off again if I close and re-open Settings. Iâm guessing the Sync chain key is stored in Seahorse somehow and is inaccessible when itâs locked, but the browser doesnât have a way of providing feedback here to tell me thereâs an issue.
If I close Brave, unlock Seahorse, and then open Brave again â no prompting, and, my Sync settings are back to normal. Same thing if I log out, but log back in using a password, since Seahorse will get unlocked.
I havenât seen any crashes or any âInternet not workingâ stuff. Whatever is going on there, I suspect is a separate issue specific to the OP.
