JMPT token not appearing in CELO network
Is the issue occurring on a specific network?
CELO network
What operating system are you using? Windows 10
Brave Version (check About Brave): v1.51.118
Additional Information: I have my imported address in the brave wallet. I added the CELO network and the JMPT asset but I don’t see it.
https://celoscan.io/address/0x9F84d050fB4dF076A7d59ba5E5e3d973baA9De28. I should see these tokens in the brave wallet, shouldn’t I?
Thanks for your help
I have used another wallet and I can see my tokens. There seems to be a bug or misconfiguration on your side. I followed the “add the network” from the options, but unsuccessfully.
hi @neroxyr ,
Yes it should be there. Can you double check a few things for me ?
  • that you are looking at the same wallet address in brave wallet as you are in celoscan
  • can you check to see if its the right contract address for JMPT asset in brave wallet
Let me know if that works for you.
Thanks,
Hubert
Thanks, I search for the token and it was filled automatically. I enter the info manually and I see them. Thanks.
Does brave wallet supports transactions between networks?
