In Brave (last 2 versions at least) when I put a “debugger” inside my javascript code, the execution stop correctly but the text is “black and white” and I cannot inspect the variable values by hovering inside my code. It works fine in chromium
**Steps to Reproduce
Open the dev tools on any tab
Inside the console run:
let foo='bar'; debugger;
Actual Result:
In Brave, the code is not highlighted (black and white) and hovering the cursor on a variable shows nothing
In chromium, the code is highlighted (color) and hovering the cursor on a variable shows its value
Everytime
page in the main menu):
Brave: Version 1.2.41 Chromium: 79.0.3945.88
OS: Osx Mojave 10.14.5 (18F132)
