Issue with HTTPS Everywhere and localhost
https
I want to use HTTPS Everywhere, but I want to prevent it on a few certain domains… specifically domains setup in my hosts file for the loopback ip.
I can get “127.0.0.1” and “localhost” on HTTP just fine, but when I use a domain for example “myproject.dev” which has a listing in my hosts file as “127.0.0.1 myproject.dev” I am sent to HTTPS and I can’t seem to find a way to fix it.
Currently, I am sent to HTTPS even when it is completely turned off… BUT I can access 127.0.0.1 over HTTP without any issue.
Hi @p_s,
.dev is a gTLD owned by Google. And these domains are preloaded with an HSTS header AFAIK. I think the result is same with other browsers. Maybe you can use something like .testing or .localhost instead.
Best,
:slight_smile:
closed #3
