Hello,
I want to know if it’s possible to synchronise the wallet of Brave Rewards between many PC or Smartphone ? If yes, how ?
Thanks for advence.
Hello,
Thanks for advence.
Hi @dx26d2, welcome to Community.
Can you clarify if you are referring to your Browser wallet or the new Brave Wallet?
Thanks,
Salty
Hi Salty ! Thanks you !
I just join Brave one week ago and I don’t realy know the difference between the Browser wallet and the new Brave Wallet Can you tell me more about this please ?
For my part, I’m talking about the wallet on the right top corner of the page (the triangle, where we can see our BAT), I don’t know if this can help you ?
Thanks for advence !
@dx26d2 Happy to introduce you to Brave Rewards.
If you would like to learn more I do suggest that you check out the Brave Help Center FAQ that will be able to answer your burning questions.
Thanks for these informations @SaltyBanana !
Now, I can tell you I’m talking about the new Brave wallet. Is it possible to synchronise it between many PC ?
This should help:
Oh indeed, that’s good ! Thanks you ! ^^
