Date |
15 October 2021 |
Not tested until 26 Oct 2021 |
Not tested until 21 Oct 2021 |
App Version |
1.33.7 |
Chromium: |
95.0.4638.50 (Official Build) nightly (x86_64) |
Revision: |
3e9db37693d0cf8e31a89 fbcf50401ae91125cef-refs/branch-heads/4638@{#816} |
OS |
macOS Version 10.14.6 (Build 18G9323) and macOS Version 11.6 (Build 20G165) |
Machine |
2012 13" MacBook Pro and 2015 13" MacBook Air |
Network Connection |
Ethernet and WiFi |
Printer Reset? |
Yes |
Date: |
21 October 2021 |
App Version |
1.33.23 |
Chromium: |
Didn’t catch it |
Revision: |
Didn’t catch it |
OS |
macOS Version 10.14.6 (Build 18G9323) |
Machine |
2012 13" MacBook Pro |
Ethernet |
Printer Reset? |
Yes |
App Version |
1.33.24 |
97.0.4678.0 |
97.0.4677.0 |
95.0.4638.54 |
94.0.4606.81 |
82.0.4210.0 (x86_64) |
81.0.4196.14 (x86_64) |
80.0.4170.63 (x86_64) |
Chromium: |
95.0.4638.54 (Official Build) nightly (x86_64) |
97.0.4678.0 (Developer Build) (x86_64) |
97.0.4677.0 (Official Build) canary (x86_64) |
95.0.4638.54 (Official Build) beta (x86_64) |
94.0.4606.81 (Official Build) (x86_64) |
96.0.4655.7 |
95.0.4638.32 |
94.0.4606.81 |
Revision: |
d31a821ec901f68d0d34c cdbaea45b4c86ce543e-refs/branch-heads/4638@{#871} |
547c03a5f89b035d05 3e541cde5a91cb15b21f6e-refs/heads/main@{#933912} |
10e0967034d9e327e2 0f49fffae22d2af419639e-refs/branch-heads/4677@{#1} |
d31a821ec901f68d0d 34ccdbaea45b4c86ce543e-refs/branch-heads/4638@{#871} |
5a03c5f1033171d5ee 1671d219a59e29cf75e054-refs/branch-heads/4606@{#1320} |
JavaScript: |
V8 9.5.172.21 |
V8 9.7.39 |
V8 9.7.37 |
V8 9.5.172.21 |
V8 9.4.146.21 |
OS |
Machine |
Ethernet |
Printer Reset? |
Yes |
No |
No |
No |
No |
No |
No |
No |
App Version |
1.33.25 |
Chromium: |
Revision: |
OS: |
JavaScript: |
V8 9.5.172.21 |
Machine |
Ethernet |
Printer Reset? |
Yes |
Date: |
22 October 2021 |
App Version |
1.33.27 even though it said “Update” and I applied it |
97.0.4679.0 (Developer Build) (x86_64) |
No update as of 10:34 |
No update as of 10:35 |
No update as of 10:36 |
No update as of 10:37 |
No update as of 10:38 |
No update |
Chromium: |
Revision: |
a5865bf24fb37ed6b152 16269ed6dbf895ce5d3f-refs/heads/main@{#934186} |
OS |
JavaScript: |
V8 9.5.172.21 |
V8 9.7.42 |
Machine |
Ethernet |
Printer Reset? |
No - disabled IPFS before “Update”; Yes - when enabled IPFS, which I subsequently disabled in prep for next update |
No |
Date: |
26 October 2021 |
26 October 2021 |
26 October 2021 |
26 October 2021 |
App Version |
1.33.32 |
1.32.82 |
1.32.81 |
1.31.87 |
Chromium: |
95.0.4638.54 (Official Build) nightly (x86_64) Note that this is the same version of Chromium as 1.33.24 through 1.33.27
95.0.4638.54 (Official Build) dev (x86_64) |
95.0.4638.54 (Official Build) (x86_64) |
Revision: |
OS |
JavaScript: |
V8 9.5.172.21 Note that this is the same version of JavaScript as 1.33.24 through 1.33.27
V8 9.5.172.21 |
V8 9.5.172.21 |
V8 9.5.172.21 |
Machine |
Ethernet |
Printer Reset? |
No - disabled IPFS before “Update”; Yes - when then enabled IPFS (local node as before), which I subsequently disabled in prep for next update
After doing testing with Dev and Beta, relaunched Nightly, disabled IPFS, enabled to local node, printer reset. |
No - first launch, default was IPFS set to Ask, I switched to local node, then disabled, then re-enabled to local node. Quit, relaunched, repeated IPFS changes, also enabled extension then disabled it and cycled IPFS to local node, no printer reset. |
No - first launch default IPFS set to Ask, disabled, quit, relaunched, enabled to local node, noticed that Fallback to public gateway was disabled so enabled it, disabled IPFS, re-enabled to local node with fallback on, enabled extension, cycled IPFS to local node, disabled extension, cycled IPFS to local node, no printer reset. |
No on launch w/default IPFS “Ask” No when enable No when set Fallback to public gateway No when add extension |
Command Line: |
/Applications/Brave Browser Nightly.app/Contents/MacOS/Brave Browser Nightly |
/Applications/Brave Browser Dev.app/Contents/MacOS/Brave Browser Dev |
/Applications/Brave Browser Beta.app/Contents/MacOS/Brave Browser Beta |
/Applications/Brave Browser.app/Contents/MacOS/Brave Browser |
–disable-client-side-phishing-detection |
–disable-domain-reliability |
–enable-dom-distiller |
–no-pings |
–no-pings |
–no-pings |
–no-pings |
–component-updater=url-source=https://go-updater.brave.com/extensions |
–origin-trial-public-key=bYUKPJoPnCxeNvu72j4EmPuK7tr1PAC7SHh8ld9Mw3E=, fMS4mpO6buLQ/QMd+zJmxzty/VQ6B1EUZqoCU04zoRU= |
–sync-url=https://sync-v2.brave.com/v2 |
–lso-url=https://no-thanks.invalid |
–variations-server-url=https://variations.brave.com/seed |
–enable-features=WebUIDarkMode,PasswordImport,ReducedReferrer |
–enable-features=WebUIDarkMode,PrefetchPrivacyChanges,PasswordImport, |
–enable-features=LegacyTLSEnforced,WebUIDarkMode,PasswordImport, |
–enable-features=LegacyTLSEnforced,AutoupgradeMixedContent, |
Granularity,PrefetchPrivacyChanges,LegacyTLSEnforced,Autoupgrade |
ReducedReferrerGranularity,LegacyTLSEnforced,Autoupgrade |
ReducedReferrerGranularity,PrefetchPrivacyChanges,Autoupgrade |
SafetyTip,WebUIDarkMode,PrefetchPrivacyChanges, |
MixedContent,SafetyTip |
ReducedReferrerGranularity,PasswordImport |
–disable-features=TabGroupsFeedback,AutofillServerCommunication, |
–disable-features=InterestCohortFeaturePolicy,TabGroupsFeedback,AutofillServerCommunication, |
–disable-features=InterestCohortAPIOriginTrial,ConversionMeasurement,InterestCohort |
–disable-features=AppDiscoveryRemoteUrlSearch,CopyLinkToText,FlocIdComputedEvent |
CopyLinkToText,FirstPartySets,TrustTokens,DirectSockets, |
AppDiscoveryRemoteUrlSearch,TrustTokens,DirectSockets,Floc |
FeaturePolicy,AppDiscoveryRemoteUrlSearch,FederatedLearningOfCohorts,Floc |
Logging,HandwritingRecognitionWebPlatformApiFinch,SubresourceWebBundles,Network |
InterestCohortFeaturePolicy,SettingsLandingPageRedesign, |
IdComputedEventLogging,HandwritingRecognitionWebPlatformApiFinch,Privacy |
IdComputedEventLogging,HandwritingRecognitionWebPlatformApiFinch,DirectSockets, |
TimeServiceQuerying,AutofillServerCommunication,SignedExchangeSubresourcePrefetch, |
FledgeInterestGroups,FlocIdComputedEventLogging, |
SandboxSettings2,IdleDetection,CopyLinkToText,FledgeInterestGroups,Settings |
TrustTokens,LiveCaption,SignedExchangeSubresourcePrefetch,NavigatorPluginsFixed, |
NavigatorPluginsFixed,LiveCaption,TrustTokens,DirectSockets,FirstPartySets, |
HandwritingRecognitionWebPlatformApiFinch, |
LandingPageRedesign,SignedExchangePrefetchCacheForNavigations,Network |
SubresourceWebBundles,NetworkTimeServiceQuerying,FledgeInterestGroups, |
InterestCohortAPIOriginTrial,WebOTP,ComputePressure,NotificationTriggers, |
AppDiscoveryRemoteUrlSearch,LiveCaption, |
TimeServiceQuerying,SubresourceWebBundles,NavigatorPluginsFixed,Signed |
SettingsLandingPageRedesign,CopyLinkToText,ComputePressure,NotificationTriggers, |
SignedExchangePrefetchCacheForNavigations,SettingsLandingPageRedesign, |
ExchangeSubresourcePrefetch,InterestCohortAPIOriginTrial,FledgeInterestGroup |
WebOTP,PrivacySandboxSettings2,IdleDetection,SignedExchangePrefetchCacheFor |
FledgeInterestGroups,InterestCohortFeaturePolicy,PrivacySandboxSettings2, |
PrivacySandboxSettings2,IdleDetection,InterestCohortAPIOriginTrial, |
API,AutofillEnableAccountWalletStorage,FirstPartySets,ReadLater,TextFragment |
Navigations,FirstPartySets,AutofillServerCommunication,TabGroupsFeedback, |
IdleDetection,ConversionMeasurement,FederatedLearningOfCohorts,Autofill |
FledgeInterestGroupAPI,AutofillEnableAccountWalletStorage, |
Anchor,ConversionMeasurement,FederatedLearningOfCohorts,LiveCaption, |
AutofillEnableAccountWalletStorage,FledgeInterestGroupAPI,TextFragmentAnchor |
EnableAccountWalletStorage,FledgeInterestGroupAPI,TextFragmentAnchor,ReadLater |
ComputePressure,NotificationTriggers,WebOTP,ReadLater, |
ComputePressure,WebOTP,NotificationTriggers |
ReadLater |
TextFragmentAnchor,ConversionMeasurement, |
FederatedLearningOfCohorts,SignedExchangePrefetchCache |
ForNavigations,SubresourceWebBundles,NetworkTimeServiceQuerying |
–flag-switches-begin |
–flag-switches-end |
Executable Path: |
Profile Path: |
/Users/[username]/Library/Application Support/BraveSoftware/Brave-Browser-Nightly/Default |
/Users/[username]/Library/Application Support/BraveSoftware/Brave-Browser-Dev/Default |
/Users/[username]/Library/Application Support/BraveSoftware/Brave-Browser-Beta/Default |
/Users/[username]/Library/Application Support/BraveSoftware/Brave-Browser/Default |
Linker: |
lld |
lld |
lld |
lld |
Variations: |
AdRewardsStudy:NextPaymentDay |
ExtendedVariationsSafeMode:Control2 |
AdServingStudy:MaximumAdNotificationsPerDay=100/ MaximumInlineContentAdsPerHour=8/MaximumInlineContentAdsPerDay=40 |
AdvertiserSplitTestStudy:GroupA |
BraveAds.FrequencyCappingStudy:ExcludeAdIfWithinTimeWindow=0h |
BraveAds.ShowCustomAdNotificationOnMacStudy:Default |
BraveAds.ShowCustomAdNotificationOnMacStudy:CustomAdNotificationPositionedBottomRight |
BraveAds.UserActivityStudy:Triggers=EMPTY/Threshold=0.0/IdleTimeThreshold=5 |
BraveTalkStudy:Enabled |
ConversionsStudy:NewDefaultPattern |
Default1pBlockingStudy:Disabled |
EphemeralStorageStudy:Enabled |
MacCoreLocationBackendStudy:Enabled |
NativeCosmeticFilteringStudy:Enabled |
OperationalPatternsCollectionStudy:Enabled |
PartitionConnectionsByNetworkIsolationKeyStudy:Enabled |
PermissionLifetimeStudy:Enabled |
PermissionLifetimeReleaseStudy:Enabled |
