iPad does not sync but other device will (however only with nightly)
Ipad does not successfully sync to the sync chain
  1. Create sync chain on PC (using Beta version)
  2. Only could sync with android using the nightly version of brave (beta sync crashes, official does nothing)
  3. Tried to sync iPad to the chain from both the android QR code and PC QR code
[Version 1.12.91 Chromium: 84.0.4147.89 (Official Build) beta (64-bit)]
[Version 1.13.26 Chromium: 84.0.4147.89 (Nightly Build) - Android]
[Version 1.18.1 (20.07.06.15) - Ipad]
Mobile Device details
Android 10; SM-G973U Build/QP1A.190711.020
Ipad 13.6 (17G68)
Ipad acts as if it is connected to the sync chain but more like it created its own sync chain. Tried to delete the device from the iPad itself and retry several times with no such luck.
On the PC in the sync menu, it shows the android and the PC synced. Ipad never shows up.
Because it’s two different Sync version. iOS is still have v1 and desktop and Android will have v2. Brave Sync v2 soon available in Nightly, will disable Sync v1 and https://support.brave.com/hc/en-us/articles/360021218111-How-do-I-set-up-Sync-
