Installed system printer not found in Ubuntu 21.04
Attempting to print on a Ubuntu 21.04 freshly installed system. Only printer available to brave is a ‘print to PDF’. The system has found and installed an HP M277 network printer.
Printing to PDF and then opening in a PDF viewer and printing to the printer works. Clicking the “manage” button opens the system print window, which shows the installed printer.
Expected result: Brave detects system configured printer
Brave Version( check About Brave): [Version 1.26.74 Chromium: 91.0.4472.124 (Official Build) (64-bit]
Followed this post - no change - https://chromeunboxed.com/how-to-use-your-hp-printer-with-linux-on-chrome-os/
sudo apt-get install cups
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
cups is already the newest version (2.3.3op2-3ubuntu3).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
$ sudo apt-get install system-config-printer
system-config-printer is already the newest version (1.5.15-0ubuntu1).
sudo apt-get install hplip
hplip is already the newest version (3.21.2+dfsg1-2).
