My max bat is 5 bat but min bat only 2.8 .I don’t know how it works.can someone please explain that thankyou!!
Who is your verified custodian? Zebpay
**Are you in a supported region?
India
India
The earnings display does not guarantee maximum earned, but is an estimation on what is to be paid out for the next month.
Thank you!
@Krishna1 without going into deep detail, the estimated earnings are always an approximation of what you get per ad. However. there are a lot of factors involved on earning. For example, we have a maximum amount of times we can view or earn BAT from some ads. Also, we can’t get paid for ads that come from countries outside of our own (so like if you are using a VPN to appear in a different country, you earn nothing)
Each time an ad is shown to you, the browser kind of takes a small note of it and has an estimation of what you might earn. But then later, it reconciles the information with its servers to determine if you exceeded view limits, were in the correct country, and a bunch of other little things.
So only thing being said is you will get paid at least what’s in the minimum and might be able to get as much as the maximum. Typically by time everything reconciles, we never get the maximum though.
