Improved right click menu for bookmarks
It would be very convenient if you could click options in the right click menu of a bookmark (i.e. the menu that pops up after you right click a bookmark), without the entire bookmark menu closing itself immediately afterwards. Because this makes it very annoying to batch delete or edit bookmarks, especially if you have a long bookmark menu that you need to scroll all the way down every time… I do not think it would be very difficult to implement this feature, but it would be quite a quality of life improvement, so I hope you will consider it.
i have the same problem, not found a suitable extension ether…please notify if you find a solution
