Briefly describe your issue:
I first downloaded Brave stable then nightly on both my Android phone and Windows 10. I want to sync all my BATs to my wallet (which I verified with Gemini). Then uninstall the Brave Nightly (which I still have everywhere) on all of my devices.
I want to use the Brave Stable across all of my devices with one wallet (Gemini), preferably Uphold (if possible). And I’d appreciate a list of wallet services supported by Brave.
What Operating System and Brave version are you using ( Menu --> About Brave
Android 12, Brave 1.37.112, Chromium 100.0.4896.79
On this current Brave Stable, no. It doesn’t give me the Gemini option like the other ones, except Uphold. But it is verified on the other devices.
April 10, 2022
No, because I just started using Brave this month.
Are you using a VPN? (yes/no)
Yes.
Yes, I am in the US.
Yes, it did.
I have not. And I use Gemini. I would love to use uphold. But it seems like it’s not supported in my state.
P.S: I posted on Brave Community over two weeks ago and never got any help. Looking forward to getting it in the foreseeable future.
