Icon does not work. Starting Brave from terminal window, troughs bundle of errors in Ubuntu 18.04 LTS
frank@frank-ThinkPad-T460s:~ brave main.go:224: cannot change mount namespace of snap "brave" according to change mount (/snap/gtk-common-themes/818/share/icons/Suru /snap/brave/44/data-dir/icons/Suru none bind,ro 0 0): cannot use "/snap/gtk-common-themes/818/share/icons/Suru" as bind-mount source: not a directory Gtk-Message: Failed to load module "canberra-gtk-module" Gtk-Message: Failed to load module "canberra-gtk-module" Gkr-Message: secret service operation failed: An AppArmor policy prevents this sender from sending this message to this recipient; type="method_call", sender=":1.118" (uid=1000 pid=8315 comm="/snap/brave/44/opt/brave.com/brave/brave --no-sand" label="snap.brave.brave (enforce)") interface="org.freedesktop.DBus.Peer" member="Ping" error name="(unset)" requested_reply="0" destination="org.freedesktop.secrets" (uid=1000 pid=2984 comm="/usr/bin/gnome-keyring-daemon --daemonize --login " label="unconfined") Segmentation fault (core dumped) frank@frank-ThinkPad-T460s:~ brave
Gtk-Message: Failed to load module “canberra-gtk-module”
Gkr-Message: secret service operation failed: An AppArmor policy prevents this sender from sending this message to this recipient; type=“method_call”, sender=":1.124" (uid=1000 pid=9397 comm="/snap/brave/44/opt/brave.com/brave/brave --no-sand" label=“snap.brave.brave (enforce)”) interface=“org.freedesktop.DBus.Peer” member=“Ping” error name="(unset)" requested_reply=“0” destination=“org.freedesktop.secrets” (uid=1000 pid=2984 comm="/usr/bin/gnome-keyring-daemon --daemonize --login " label=“unconfined”)
Gkr-Message: secret service operation failed: An AppArmor policy prevents this sender from sending this message to this recipient; type=“method_call”, sender=":1.124" (uid=1000 pid=9397 comm="/snap/brave/44/opt/brave.com/brave/brave --no-sand" label=“snap.brave.brave (enforce)”) interface=“org.freedesktop.Secret.Service” member=“SearchItems” error name="(unset)" requested_reply=“0” destination=“org.freedesktop.secrets” (uid=1000 pid=2984 comm="/usr/bin/gnome-keyring-daemon --daemonize --login " label=“unconfined”)
[9397:9519:0118/074710.420737:ERROR:udev_watcher.cc(60)] Failed to begin udev enumeration.
[9397:9397:0118/074834.092555:ERROR:input_method_base.cc(146)] Not implemented reached in virtual ui::InputMethodKeyboardController *ui::InputMethodBase::GetInputMethodKeyboardController()Using InputMethodKeyboardControllerStub
[9397:9397:0118/074931.149212:ERROR:textfield.cc(1767)] Not implemented reached in virtual bool views::Textfield::ShouldDoLearning()
On top of this. IS this right that install and deinstalls takes up more snaps?
Snap packages are no longer supported by Brave. Please use the following instructions to install Brave:
