Too many sync devices i was hoping some could be moved i have the sync code if you can i am always restarting my pc adding things and doing all these things and i forget to leave my sync everytime
None
first time
Brave Version(See the About Brave
page in the main menu):
1.63.74
Type of devices currently running on the Sync chain in question:
Windows pcs.
I am not in the sync code right now there are too many accounts in mine
@Gersky I’m a little confused on your issue. If you look under Sync, you can remove devices yourself, such as you see in screenshot below:
You’d just click the and it would remove the device from the sync chain.
i can’t remove it i factory reset i needed someone to remove it for me
Nobody can access your Sync, only you. You’re saying you have 10 devices on the sync chain but no control over any of them? If so, then you’re just out of luck. That sync chain won’t be able to be accessed and will eventually be deleted for being inactive.
