I have sent DPR tokens on BNB binance smart chain BEP20 address
NOTICE: Please only post Brave Wallet/Crypto wallet inquiries in this category – please go here for Brave Rewards support
Are you using the (new) Brave Wallet or the (old) Crypto wallets implementation?
Brave Version (check About Brave):
Additional Information: I have sent DPR tokens on BNB binance smart chain BEP20 address. I did not notice that brave wallet does not support DPR tokens yet. What can be done regarding this?
@blockchain_beta please do not reply or go to the message sent by @Sandeep11 it’s a scam.
thanks for the info brother
No problem. I’ll tag @hub @onyb to assist here. As I am not sure how that would work.
If possible, do flag the scam post so
We support all BNB Chain tokens. Have you made sure DPR is added to your Visible Assets list? If not, you can add it from the main portfolio page by clicking on the “Visible Assets” button. If you can see the DPR balance for your address on bscscan, you can be assured that you’ll be able to use it in the wallet.
