How to solve *almost* every problem after install
WARNING : You will lose all your data(bookmarks, Brave wallet, etc.) with this. Use sparingly.
Here is a step-by-step guide for what we might otherwise call ‘the nuclear option’.
If you are having any problems from a corrupted profile, bad shortcuts, etc. this will certainly get you back to square one.
For Windows Users :
  1. Use Add/Remove Programs to uninstall Brave (Start > Run > appwiz.cpl)
  2. Go to “%userprofile%\AppData\Local” and delete the “brave” folder (Start > Run > paste path)
  3. Go to “%userprofile%\AppData\Roaming” and delete the “brave” folder (Start > Run > paste path)
  4. Delete all copies of installers
  5. Delete shortcut from desktop + taskbar
  6. Restart computer
  7. Re-download the latest Brave installer from www.brave.com
  8. Run the installer
  9. App should open up at the end. Close it
  10. Launch from desktop shortcut
For Mac Users :
  1. Delete the Brave.app file from Applications (or whichever alternative location you have selected)
  2. Delete the folder located at “~/Library/Application Support/brave” (open Terminal.app and use the command ‘rm -rf ~/Library/Application\ Support/brave’)
  3. Restart computer
  4. Re-download the latest Brave installer from www.brave.com
  5. Run the installer
Doesn't import bookmarks from Firefox
MS deleted Brave functionality
Crashes and needs uninstall + reinstall regularly
Resetting Brave doesnt work
Brave won't install on Windows 10 laptop
Browser Freezing
How to reset Brave browser
(Solved) Brave installs, then disappears - almost without a trace
Browser will not load on windows 7 64 bit.IE 11
Brave (Win10-64 Pro) ceases to load, reinstalling does not fix
Brave Browser Data Erased
Updating Brave issue
Start up Brave ok but closes in .2 sec
Brave remains open for only a second
Even after shutting down computer, Brave is keeping me logged in to everything?
No PDF Viewer extension
Welcome to community.brave.com
Bookmark toolbar has a blank icon that I can't remove
Mac OS 10.14.2 Brave (Stable) freezing on launch
Can't reset Brave to default (Mac)
Brave keeps shutting down!
All Audio & Video Media Buffers/Freezes From All Sites Only In Brave On Multiple PCs
Brave auto-update failing on Win7 x64
Had to delete and reinstall, now all of my bookmarks are gone even with sync
Brave only works with v.0.18.23.0 and upon updating, brave refuses to open. please help. I havent been able to use brave in 8 months because of this issue
Brave crashes even after re-installation
How do I subscribe to the Dow Jones Media Group?
Logged Out After Brave Restarts
Metamask files after uninstalling Brave
Worldtimebuddy crashes brave
Address bar lag
Brave 0.15.314 Google Maps Freaks Out on Mac OS 10.10.5 [video]
Brave Payments not working for me
pinned #2
closed #3
#4
Shouldn’t %userprofile%\AppData\Local\ be %userprofile%\AppData\Roaming\?
Roaming is the folder which contains a Brave profile, not Local.
#5
I think this was first written up when we were having more installer-based issues instead of corrupted profiles. I’ll update this now :slight_smile:
Now they will remove both. We probably still need to add some data extraction scripts soonish if we are going to continue to recommend this option.
#6
Think this should still be kept since it’s about solve almost every problem which is being called as the nuclear solution.
Just edit that step and mention
clear profile - delete brave folder under %appdata%
complete installation - delete brave folder under %appdata% and %userprofile%\appdata\local
Completely Blank Window after update
