How much is battery usage on Surface?
This topic is for discussion of the issue reported below:
https://github.com/brave/browser-laptop/issues/3014
after a recent update the browser is at 76% battery usage on my Surface Pro 3. It’s drastically reducing the battery time of my computer. To give you an example my computer showed 13 minutes of battery life remaining while using Brave. Upon closing Brave and switching to Edge it went up over an hour. I’m not sure what happened as Brave used to only use around 30 to 40 percent of my battery time.
I myself did not experience the issue. It’s been reported on the old support desk.
If you have Surface, would you confirm how much battery usage is? Is it too high?
Thanks in advance :smile:
closed #2
