Higher battery consumption
I think the battery consumption has been increased when compared to older versions for the same tasks.
I will need to cc @serg on this :slightly_smiling_face:
Brave on the most consuming apps in battery settings?
#3
@Giridhar do you have any comparison table?
#4
I’ll make one. I made this post based on my observation in battery stats.
#5
@Giridhar thank you, it would be very helpful.
closed #6
