Help With Homescreen on Android
How can I remove the black box at the top of the Android screen which show Trackrs & Ads Blocked > Est Data Saved > Est Time Saved
brave://settings/newTab
On Android I have under Settingx New Tab Page and ALL that that allow is turnin OFF background images and/or show top sites. The Appearnce settings doen’t show anything relevant either
Maybe there
Android New Tab Page setting only has the options to Show Background Images ON/OFF > Show Sponsored Images ON/OFF > Show Top Sites ON/.OFF i need a way to get rid of the black box underneath the URL Bar which shows > Trackers & Ads Blocked > Est Data Saved > Est Time Saved - Can’t use the app until I get rid of this intrusion.
