I’ve recently started using Brave browser, and one thing I’m used to in Firefox was my Equalizer always being turned on. I installed five different Equalizer extensions for Brave, while searching for an extension, which would run in the background 24/7, but all of those extensions have to be manually enabled for each new tab. And it’s irritating.
I assume that the issue isn’t with the extensions, but with how Brave is built (some protection to stop extensions from having too much power). Is there something like a config page I can edit to bypass this limitation and just have my Equalizer extension run all the time in the background for all my windows and tabs?
- go to https://chromewebstore.google.com/search/equalizer
- for example, download “Advanced Audio Equalizer” by viiny.com
- open the Equalizer, and enable it
- observe that it only enables for the current tab
it appears that every Equalizer extension is limited to a single tab
once enabled, the Equalizer extension should stay enabled for every tab
100%
page in the main menu):
Ubuntu 24.04.2 LTS
Version 1.77.101 Chromium: 135.0.7049.115 (Official Build) (64-bit)
If this isn’t the right place to post this topic, please direct me to the correct category. Thank you.
