Hi, I need help with this problem, I have made a search in the community but the solution I have found is that I have to deactivate the rewards…
The problem is when I’m using brave my hard disk usage is always at 100% and I have discovered that only occurred when the rewards option is active, why is this happen.
I don’t want to have to deactivate the rewards, this is the main reason why I’m using this browser.
