How does one make Gibiru their default search engine?
Thanks
Hi, click on the 3 bars in the upper right corner (menu) -> Settings
Scroll down to “Search engine” -> Manage search engines
Under “Other search engines” click on Add.
The following has worked for me to use your search engine via the address bar:
(Text unfortunately in German)
Don’t forget to search for your search engine in the upper right corner and set it as default over the 3 points.
