Fullscreen problem with Investing.com streaming charts
Description of the issue
When clicking the fullscreen icon for the streaming charts, nothing happens. Right next to the “streaming charts” is a link for “interactive charts”. If I go to that link and hit the fullscreen icon, those charts will open in fullscreen. Unfortunately, I need to use the streaming charts and not the interactive charts. (The streaming charts actually went fullscreen in the Brave legacy version 0.25.2)
Exact URL of the website in question
https://www.investing.com/indices/nq-100-futures-streaming-chart
Did the issue present with default Shields settings? [Default states are: Block: Ads/Trackers, 3rd Party Cookies, 3rd Party Fingerprinting Allow: Encrypt Connections enabled (HTTPS), Scripts] (yes/no)
Does not function with Shields on or off.
Does the site function as expected when Shields are turned off? (yes/no)
No
Is there a specific Shields configuration that causes the site to break? If so, tell us that configuration. (yes/no)
No
Does the site function as expected when using Chrome? (yes/no)
Yes, when I use Chrome this icon will expand the charts to fullscreen.
What Brave version/Build are you using when you encounter the issue?(About Brave info)
Version 0.57.18 Chromium: 71.0.3578.80 (Official Build) (64-bit)
