Recently I was offered the opportunity to use Brave Search Engine on my iPad. As a trial I though I would give it a try.
I had been using DuckDuck Go prior to this.
The search results appear in such a small font that the results only take up a little more than half the width of the screen.
Yes, I can expand the view but this is a nuisance and does not occur with DDG or other search engines I have used.
To Reproduce: Launch Brave Browser on iPad 6 in Portrait view, perform a search using Brave’s Search Engine. Try the same search with DuckDuck Go or other browser (untested).
Expected result: Same size Font in all search engines
**Brave Version 1.40 (22.6.29.0)
Apple iPad 6th Generation
iPadOS 15.5
